Learn from the mistakes of others. You won't live long enough to make all of them yourself
ALL OF THESE WILL BE LINKS TO THE POST OF OTHER THAT HAVE A DETAILED WRITE UP OR THREAD WHICH COVERS SOMETHING SPECIFIC. THAT WAY WE DONT HAVE 9,000 POSTS ABOUT THINGS LIKE "CAN WE TURBO...." , "HOW DO I....", AND SO ON.
ECU'S
Factory Atlas ECUs: The Basics You Need To Know For Your Vortec 4200 - 2800 Swap
PARTS
FIRST AND FOREMOST, "WHO MAKES X FOR Y ENGINE" CHECK THE VENDOR SECTION
ALSO CHECK OUT J WHITS RUNDOWN JUNE 17, 2024 ATLAS 4200 Builds Have NEVER Been Easier! Aftermarket Overview! *MORE HAS COME ONLINE SINCE THEN...
GM's Best Kept Secret: The Ultimate Guide to the Vortec Atlas 4200
CHARGING/ALTERNATOR OPTIONS
COOLANT BLOCK OFF PLUGS
ENGINE BUILDS BY CALVIN
Building the Ultimate 800HP Street Vortec 4200 for the 10 Second Trailblazer
Building The Engine For The American Supra (1000HP)
Can We Make This Pontiac Sunbird Super Fast for Just $10,000? (ANOTHER 800 HP BUILD)
Preparing an Ameri-Barra Vortec 4200 for an 8 second Drag Car
Preparing The "NEW" Engine For The Futura LIVE STREAM
Autopsy - Why did our 800 WHP Ameri-Barra Vortec 4200 Blow Up? TEARDOWN NOT A BUILD UP
FAQ'S / HOW TO / SPECS / TECH
QUICK LINKS TO MOST FAQ, HOW TO'S, ETC. SEE IF ITS HERE FIRST!
Return to “FAQ'S / HOW TO / SPECS / TECH”
- ↳ HAS ANYONE SWAPPED X INTO Y!?
- ↳ WHO'S GOT A REPUTATION?
- ↳ CUSTOM ALLOY WELDING (BANNED)
