AR5 SLAVE CYLINDER SPACER
AR5 SPACER.bmp (454.15 KiB) Viewed 288 times
This spacer moves the slave clutch cylinder toward the flywheel and prevents over extension of the slave cylinder.
Shipped with the correct length mounting bolts (qty. 2)
AR5 Slave cylinder spacer
Note: For use with AR5 transmissions sourced from Colorado/Canyon trucks.
