DROP IN INJECTORS
DROP IN INJECTORS
DROP IN INJECTORS
In Constant Pursuit of Excellence Quality, Craftsmanship, Value
Whether you are building a 4,5, or 6 cylinder Atlas, we have you covered. Our drop in injectors come in various rates depending on your application or goals. Each injector is developed from a Genuine Bosch injector. We flow balance them across the entire RPM and PW range and provide you with highly detailed flow reporting and tuning data (SAE and ECU Tuning Data created by Calibrated Success inc / Greg Banish).
Pro-Series - Vortec 4200 2200cc/min, 210lb/hr Set of 6 injectors
210LB/HR SET OF 6
Pro-Series - Vortec 4200 1100cc/min, 110lb/hr Set of 6 injectors
110LB/HR SET OF 6
Pro-Series - Vortec 4200 625cc/min, 62lb/hr Set of 6 injectors
62LB/HR SET OF 6
Screenshot 2025-07-26 213621.bmp (1.07 MiB) Viewed 142 times
Pro-Series - Vortec 3500/3700 2200cc/min, 210lb/hr Set of 5 injectors
210LB/HR SET OF 5
Pro-Series - Vortec 3500/3700 625cc/min, 62lb/hr Set of 5 injectors
62LB/HR SET OF 5
Screenshot 2025-07-26 213607.bmp (1.07 MiB) Viewed 142 times
Pro-Series - Vortec 2800/2900 2200cc/min, 210lb/hr Set of 4 injectors
210LB/HR SET OF 4
Pro-Series - Vortec 2800/2900 1100cc/min, 110lb/hr Set of 4 injectors
210LB/HR SET OF 4
Return to “SNAKE EATER PERFORMANCE”
