ATLAS STEEL FLYWHEEL
Specifications
29# weight
2nd generation design effective July 11/2024
Clutch side is drilled for a 10.5" SBC clutch pressure plate. You must use shoulder bolts to attach the pressure plate such as ARP 130-2201
Supplied with a factory installed ring gear.
The flywheels are in stock and shipped direct from the manufacture in the US. Comes balanced and ready to install.
Contact us to order using the contact button or direct email [email protected]
