MEGA/MICROSQUIRT
Posted: Mon Jul 07, 2025 3:08 am
I make no guarantees that any of the tunes will work and/or not blow your stuff up. I've had lots of success but use at your own risk.
Ford Fairmont - Microsquirt, 2008 Engine with Precision 5976E turbo, 3 bar MAP, Flex, ~100pph Chinese injectors. Ran 9.98 at 134mph:
Fairmont (1).msq
(119 KiB) Downloaded 74 times
Here's a data log too:
FAIRMONT LOG.mlg
(3.17 MiB) Downloaded 76 times
Please note that this was done with Open Loop VVT control via the 2-wire idle control feature wired to the VVT solenoid.
Studebaker Lark - MS3 Goldbox, 2004 Engine with Chinese GT3582 turbo, 3 bar MAP, Flex, ~100pph Chinese Injectors. Made 450whp:
MS3 GOLDBOX.msq
(285.32 KiB) Downloaded 86 times
I'm almost certain that the 06+ actuator will require different tuning on the VVT PID values. Use at your own risk.
