ATLAS ENGINE DEEPER DIVES:
Links to his videos with descriptions for easier sorting and referencing.
Locked
HERE IS A COMPILATION OF DEEPER DIVES:
VORTEC 4200 VS 2JZ
This American Engine Could Be The Next 2JZ
ATLAS CAM INSTALL KIT INSTALLATION:
Introducing Vortec 4200 Cam Install Kits for your Schneider Cams
ATLAS HEAD REMOVAL FROM A JUNKYARD
How to Pull a Vortec 4200 Cylinder Head from the Junkyard
VORTEC 4200 ENGINE DIFFERENCES
Vortec 4200 Engine Differences 13DEC2020
Changes and advancements on Ameri-Barra Vortec 4200 DOHC VVT Inline 6 Trailblazer engines over the years and recommendations on which parts to use. We look at the connecting rod designs, crankshaft designs, cylinder head designs, exhaust manifold designs, the different PCM ECU revisions and which one is best for your goals.
Is Inline 6 Engine Better Than A V8?
DIFFERENCES BETWEEN THE ATLAS 4,5, AND 6'S
Today we do a comparison between the Vortec 2800/Vortec 2900 4 cylinder vs the Vortec 3500/Vortec 3700 5 cylinder vs the Vortec 4200 6 cylinder engine."
GM Atlas 4 vs 5 vs 6 Cylinder Engine Comparison
MAKING AN ATLAS TO GM TRANSMISSION ADAPTER
How to make Vortec 4200 Adapter Plate mount with Chevy Transmission Bellhousing Bolt Pattern
Locked
Return to “Calvin's Corner (NIVLAC57)”
